My dishwasher is 3 years old and last week it was making very loud noises and now today it isn’t working.
The green light blinks clean. When I push start it blinks 3x and does nothing. When I push cancel it says 2 minutes for the time remaining and makes noise for 2 minutes and shuts off.
If I push normal wash and push start it blinks 3x and shuts off. Or if I push any button to wash and push start it blinks 3x and does nothing.
Hi There,
I just read a post else-where that suggested the following to reset the dishwasher push the sanirinse button-dry button-sani-rinse button-dry buttonin that orderWhen I did this I got some spurious readings on the panel. But these disappeared when I pushed the cancel button.
I was then able to start a normal dishwasher cycle. Good Luck!
My cleaning light was blinking as well and all I did was push the sanirinse button, dry button, sanirinse button, dry buttonin this order and the dishwashers buttons all flashed; ran through some type of cycle and stopped. It now runs fine! Thanks for the quick fix and for the extra bills in my pocket.
rwroosa said:
I have a Whirlpool Silent Partner III model number GU1200XTLQ3. The other day I discovered the lights on the control panel were blinking on and off continuously. I attempted to push the cancel button, holding it for about 3 or 4 seconds, but nothing happened. I then tried the other buttons and nothing. I went out to the breaker box and cut the power. I waited for about 5 minutes and then reset the circuit breaker. The machine attempted to restart, but stopped suddenly and the lights began flashing on the control panel again. I cut the power once again and began searching the internet for clues. I finally stumbled across this forum where I read a post about resting the dishwasher by pressing and holding a button for approximately 4 seconds. By this time it had been about 24 hours since my dishwasher had power. I went out and turned the circuit breaker back on. My machine began it’s wash cycle and I waited with cross fingers. I press the cancel button and the machine stopped. I loaded some dishes and pressed a wash option. The machine started again and seems to be operating properly again. I guess I unknowingly reset the machine by leaving the power off for awhile. I don’t know if this information will help anyone, but I posted my experience in hopes that it will save someone some money.
Shutting the breaker off for 2 hours worked.
Whirlpool Gold QP111 - tried pushing normal, light, pots and pans - nothing lit up. The only button I could use was the "cancel" - that would run but nothing else. Tried the suggestion on this forum - turned off at the breaker for about 15 mins then hit sani rinse/dry/sanirinse/dry. The machine cycled through a diagnostic and when it stopped I was able to start the cycle - have not had a problem since!
I have the same model dishwasher and was just going to pay $365.00 for a repairman to fix a problem that I just researched and fixed myself!! No tools needed!! Try this-
push normal wash, heat dry, normal wash, heat dry, normal wash, heat dry and repeat this until all the lights of the panel are on, make sure the dishwasher is closed then hit start! Like magic my washer just started working a few minutes ago after doing this! Hope this helps you!
Hi There, I just read a post else-where that suggested the following to reset the dishwasher push the sanirinse button-dry button-sani-rinse button-dry buttonin that orderWhen I did this I got some spurious readings on the panel. But these disappeared when I pushed the cancel button. I was then able to start a normal dishwasher cycle. Good Luck!
I SIGNED UP SO I CAN THANK THIS GUY (OKOLEHAU) BECAUSE IT FIXED MY DISHWASHER…
T H A N K Y O U
After 1 week of this same issue "runs for a few seconds and shut off", I finally relented to my wife’s "gentle pressure" to fix the dishwasher. This trick worked for me! Once again, I am a hero, for now.
Thanks Again!
worked like magic. only thing i did different is i unpluged washer instead of turning off breaker. washer is working now. keep fingers crossed and hope this fixes problem for good. you guys just saved me a fortune on repairs and service! Thanks a bunch!
okolehau said: Hi There,
I was then able to start a normal dishwasher cycle. Good Luck! Thankyou!!!
