Can you tell me how to do this?
This should help http://www.applianceaid.com/adaptive_defrost.html
Nat
How do yo separate the top part of the agitator from the bottom to get to the dogs to replace them
Take out the fabric softener dispenser and you should see the head of a bolt (7/16"). A socket wrench with an extension will take it out and then you can lift out the upper part of the agitator that contains the dogs.
— Begin quote from lovely13675;163439
Everytime our frigidaire stops making ice it’s because I turned the temp below 6 or 7. Turn the temp up. With in minutes ours makes ice again. It’s worth the try!
You may want to measure the temperature in the freezer.
Make sure the ice maker "on-off" switch on the right side is in "on" position. Open the freezer door, press in the emitter flapper door (on the left side) to unblock the optics beam and view the diagnostics "status" LED on the right side.
Post the results.
Solid red light when flap is pushed in.
When not pushed in and door is open, two blinks, then pause, then two blinks
my 4.5 year old Kenmore mdl 106.55603400 stopped making ice 3 days ago and made one round of ice today. So 1 tray in 4 days. Replaced the PUR filter even though it was getting water in door (and continues to get water in door just fine). I’m guessing the line isn’t frozen because it filled this morning, but as stated, IM was dry for 3 days. Emitter light in freezer is blink-blink-pause-blink-blink-pause constantly, no matter if you hold the lever down on the left. Paddles in IM have been in the up position most all day and it has yet to dump today. Would really, really appreciate some wisdom. Of course this happens < 6 months out of warranty! Max temperature setting for freezer is +5, recommended setting is 0, I have it set at 1 deg. Thanks so much for your wisdom. This is a great site!
— Begin quote from Gene;330681
Looks like the problem is a bad optics.
- The PC boards kit [part]AP3137510[/part]
Gene…is this a owner servicable repair if one is pretty handy around the house?? I’ve done most everything there is to do regarding house repair/mtce, but have never worked on a frig except to replace an IM in an older frig. Thanks much for the quick reply!
— Begin quote from moncler6p;331581
No! Luckily, you will can be found throughout some really terrific restoration stores about now providing a ghd website repairs program for small money.
WTHeck? Did you get on the wrong thread? My issue has nothing to do with hair care…it has to do with an IM in a Kenmore SbS frig…this is an appliance "repair forum"!
There is nothing complicated. Do not forget to unplug the refrigerator prior to the repair and try not leave some extra parts. LOL
Many thanks for the advice Gene. Got my parts, got them installed. you’re right it was a snap; followed the instructions for testing and we’re back to making ice. I got it installed and running same day as receiving the parts from APP!
Again, much thanks! I’ve already told 2 folks about the site and how good the advice was!
You are very welcome. I’m glad you were able to fix it and thank you for the referrals.
MrFixItAlready! said:
My Whirlpool GD2SHGXLB00 side-by-side also does not make any ice. A couple of weeks ago we came home from being out of down for a couple of days and found water all over the floor. The ice maker had either overflowed or just not frozen any of the incoming water for a short period because when we opened the freezer door there was frozen water all over the side of the ice maker, the shelves, the door’s shelves, the bottom of the freezer and all of the ice in the tray was frozen into a solid block. The ice maker has not made any ice since then.After reading through the prior posts, I tried reversing the solenoid connectors for the water fill valve and didn’t get any water coming into the ice maker. I checked the line going from the fill valve to the ice maker inlet and haven’t found any blockage, though I thought that there might be some frozen water in it somewhere. So what is the likely part that’s gone out?
Very likely the water inlet valve was stuck open and then broke. I would just replace the part. You may try to blow some air through the ice maker fill tube while it is disconnected from the water valve to make sure it is not blocked.
- The water inlet valve AP3160649
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=502322
Thanks Gene, I’ll get that part replaced when I can and post a reply again. However, a $60 part to get the ice maker working is a bit more expensive than a set of $1 ice trays, so it may be a while before I reply again.
My ice maker is not making ice. Okay, before I stumbled upon this awesome site I bought a new inlet valve. I connected it and still no ice. Water still not making it up to ice maker. I switched the leads as recommended on here with the old inlet valve reconnected. Water then made it up to the ice maker. So my valve was actually in good shape. What’s my next step?
Thank you!
If the water inlet valve is good and the water is coming into the ice maker as soon as the power applied to the solenoid, replace the ice maker.
- The ice maker AP2984633
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153930
Hi Gene,
I have a Kennmore Model 106.53652300 (going on TEN Years old). We had the ice maker out of service for almost two years during a kitchen remodel. The fridge was never turned off, but the water line was not reconnected to the ice maker till recently after over the whole time as described above. The ice maker worked normally for a couple of weeks and then stopped. Here are some points I will advise…:
The refrigerator always had good water filters. I pretty much removed the stock one and had one of those GE double barrel units under the sink and at the point of origination to the line supplying the fridge.
I did have problems with the freezer-to-fridge air duck mechanical unit a couple years prior. I pretty much disconnected everything to the electronic control to the air duct (sliding diffuser). I ordered the replacement part but it did not seem to want to incorporate the electronic motorized portion of the thru wall duct, so i just set it "manual" for a while. THIS WENT ON FOR A COUPLE YEARS PRIOR TO THE EXTENDED WATER LINE ABSENCE. However, I make have only recently just disconnected the Thermistor prior to the reconnection of the water line as it seemed to have no reason for connection any more.
Long and short is that the water line to the frige was re-connected recently and now UNFILTERED for the first time ever. It ran correctly for a month tops and then issues. FIRST, It just stopped kicking the ice out after it was ready to bump out. I took the ice maker out a few times washing it out and thawing it, and still the same. The first ice would load and form, but no kick out.
It should be noted that I got sloppy and broke the flapper to the Light beam control side (on the left where the four prong connection is. So I took it out of the side of the frige wall for a few days while I glued it back together. When I re-installed it, NOW THE PROBLEM IS NOT ICE AT ALL and as if there is a water supply problem too. AGAIN, the water to the door services to fill a glass still…
The water to the door spigot still work to fill a glass of water.
I have confirmed that when the door is open and I hold down the flap to block the light - the beam does go thru and IS Acknowledge by the right side (with the on/off switch), as the light stops flashing after 2-3 seconds when observing.
I have checked the main ice maker connection and it seems to be fully engaged/connected. Tonight, I Disconnected the side on the left (with 3 screws) and checked to be sure I plugger the 4 prong back up right. The only thing I note different is that I pushed it a mm further than I thought was the previous max "push down". So perhaps…
OTHERWISE, and when I wake in the morning and their is still no ice, do you have any thoughts…?
Thanks in advance!
Bill
