Whirlpool Icemaker
My icemaker will not dispense the ice cubes unless I heat up the cubes to loosen them up. I suspect the motor is getting weak. Everything else is fine. Is the motor (AP2984633 hard to rplace or would I be better off ordering the full icemaker kit ([URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=2984633&&model_id=261806&diagram_id=107583)) ?
The problem could be a bad mold heater, a fault in the module or a bad motor.
I would recommend to replace the whole ice maker. It is a little more expensive but it’s much easer and much more reliable.
replace the icemaker, it should make a tray of ice about every 2 hours if your freezer is cold enough…
Thanks to all. My new icemaker is working better now thanks to your advice.
