Whirlpool LSR6132EQ1 Washer - Doesn’t Rinse
The washer will wash, drain and stops at rinse. The timer sounds like its running and will eventually get to spin and it will spin. It just skips the rinse cycle.
In addition to that. The washer will only work on Hot/Cold setting and the water stays cold.
IDEAS…please help.
