Hello,
first post here. Can anyone offer any insights as to how you remove and replace the main tub pump gasket? Do I have to disassemble the entire pump and motor or can I just remove the housing as a whole and replace the gasket with a new one? It almost looks like the motor/pump package is pressure fitted into place or I’m I just wishing for an easy fix here? I’m unable to figure it out based on the blow-up diagram. It’s the only thing I can’t quite figure out how to do that’s on my list of seals and gaskets that need replacing. That being said in one night all of these seals started leaking…should I be thinking of a new washer instead? She still does a good job.
Thanks, Brian
