Hello
I have a whirlpool Model #TC900QPDQ1 trash compactor that I recently rebuilt. I had to replace power nuts,switch and basiclly cleaned and lubed all moving parts. It worked perfectly until today when the motor will not start. It just hums. I removed the drive gear so it is not under any load and it still will not start on its own. If you spin it in either direction it will start and run fine with what appears to be plenty of power. When the motor is coasting down you can hear what sounds like a speed sensitive switch kick in. Is there a start capacitor on this motor or any part that could be causing this problem or am I doomed to replace the motor? Many thanks to anyone that may be of help.
Vaughn
