Our Whirlpool oven has stopped working. The blower runs all of the time but when you select bake it just says 350 and does not go into a pre heat cycle and does not heat up. This failure occured after our power company changed the electric meter so when the power came back up, the oven did not work. I opened up the front panel and checked all resistances listed in the service document in the oven. The broiler element was 18 Ohms which is different than what is listed but seems correct based on the power. The blower was resistance was off what was listed as well but it is running all the time and runs and sounds fine. There are no error codes on the controller. It seems like the controller to me and I ordered one from this site but I thought I would post to see if anybody has this problem or has suggestions.
Related topics
Whirlpool oven doesn't heat up & blower continues to run | 1 | 1721 | November 20, 2010 | |
Upper oven blower doesn't work | 1 | 446 | September 6, 2015 | |
Blower Not Working | 5 | 1705 | May 13, 2011 | |
Whirlpool Oven not heating fan runs continously | 3 | 5874 | August 26, 2008 | |
Whirlpool Help, Bake does not work | 2 | 697 | January 2, 2015 |
