Whirlpool oven doesn't work after self-cleaning
My oven is about 10 years old. I haven’t used the self-cleaning for about 3 years. I just cleaned my oven using the self-cleaning mode and now the oven doesn’t work anymore. :eek: The stove top works, but not the oven. Any ideas?
Thank you :slight_smile:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RS696PXGQ2
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203192239.pdf
If everything else looks Ok but the elements do not come on it could be the over temperature thermostat (Item 37n in Section 2 is blown.
Shoukld be 0 ohms at room temperature.
Thanks for your reply… I can’t find the temperature thermostat in the parts doc… where do I look?
Item 37 in Section 2
