Whirlpool Oven not heating
Hi there~
I used the Self Clean mode today and all was well. Tonight it won’t heat either element. This is an electric single oven.
I need help because if I can fix this I installed it then I’d prefer that!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gbs277pdq11
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301758.pdf
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If power is OK then the thermostat (TOD) is next (item 37 in Section 1)
Remove power from the unit and one wire to the TOD and check it.
It should be 0 ohms.
I have the same problem after cleaning the oven. Checked the therm and it is open. Does it sound like it could be the problem.
Yes it does sound like the culprit.
