Whirlpool oven not work,stovetop works fine
Whirpool Accubake oven is not working-bake,broil or warm functions.This model has 2 spark type oven igniters, only on the broil function the sparker clicks 2 times and nothing happens. The other thing that I found is the brown wire coming from spark module(located by distribution valve) going to the bake ignitor. The plastic of the wire melted against the metal pipe that takes gas to the bake burner (element). I just wrapped the wires in electrical tape and moved it away from the pipe.
What could have happened? Did the heat from the pipe trough the wire influenced anything? We had power surges several times, could that do something to the range? Does this unit have thermal fuse, could it be the problem in it? Any suggestions?
