Whirlpool oven overheating
Set oven to Bake @ 350. The top elements (broiling element) comes on and heats the oven very hot. This display indicates the oven reaches 350 and clicks off, but the top element continues to heat to 500+ when I manually turn oven off.
The temperature sensor was replaced last month.
Does this sound like the controller needs to be replaced?
Thanks, I’ve went ahead and ordered a new control board…guess I’ll just wait and see what happens then.
I have the exact same problem! did you find a solution?
