Whirlpool Oven - Replace glass front
I have replaced the lower oven exterior glass. I released the springs and removed the door, in order to access the glass retaining clips & screws located on the bottom of the door. There didn’t seem any other way. Now… what is the trick for getting the door hinges back in place in the oven… ??? - Thanks !!
This should help, see page 2-3
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
You may want to save it for future reference.
Thanks for the quick response ! I’ll give it a try…
— Begin quote from denman;340163
— Begin quote from archwoodworking;340169
  • Tried it and it worked perfect. Knowing that a pin needed to be put in place, temporarily, in the little hole in the hinge arm (that you can’t really see) was the ticket ! I actually used the barrel end of a 5 mm shelf clip.
