Whirlpool Qt Prtnr II, Replaced Htg Element Does the Control Panel Nd 2 B Replaced?
[SIZE=3]The heating element suddenly broke in two for no apparent reason. We’ve had it since Oct 2005. I’ve purchased a new heating element however now I’ve been told that the control board needs to be replaced whenever the heating element is replaced. Is this true? Is this really a necessity any time the heating elements are replaced?[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]If yes, what is the correct part number for the control board/panel/electronic control board?[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]And can I just replace the interior electronic control board without replacing the entire Control Panel that is on the outside at the top of the dishwasher?[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Please hurry with any correct info as the dishes are piling up. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Thx,[/SIZE]
[SIZE=3]DirtyDishes4Five[/SIZE]
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DU1145XTPB3
Who told you this?
I do not see a heater and board kit listed in your parts so I am assuming it does not need a board. Also the kit is only for stainless steel tubs.
It comes as a kit. Below is an example this is for a Kitchenaide KUDI01TJBL1.
AP3841139
You could call AppliancePartsPros to confirm the above.
Yes if it needed one it would be just the control board.
