Whirlpool Quiet Partner II - Light flashes, can't get it to reset
I’ve searched several threads, but I can’t seem to find one that matches the problem that I’m having. On my unit, the light above ‘Hi-Temp Wash’ is the one that is flashing. I have read some of the other threads, and I’ve tried the ‘Heated-Dry, Normal, Heated-Dry, Normal, Cancel’ sequence that I’ve seen some people try, but that hasn’t seemed to do anything.
Sometimes, the light seems to flash in a ‘code’ manner, then it just switches to a constant flashing. I’ve tried turning the dishwasher off at the light switch, and I’ve also tried flipping off the breaker.
It was working fine this past weekend … Now it just doesn’t want to cooperate.
Any suggestions?
Thank you, so much, for any help that you can provide!!
