Whirlpool Quiet Partner II will not start
I have a Whirlpool Quiet Partner II model: DU1148XTPQ3.
Background info:
The dishwasher is against and exterior wall and the symptoms start after the cold spell in early January in the northeast. However the unit started working for a while when it warmed up and then I started to experience the symptoms below. These events lead me to believe it is related to the thermostat.
Symptoms:
  1. The unit will not start.
  2. The cancel operation works OK.
  3. Reset operation not responding. Pushed sani-rinse and heated dry three times and no blinking light reset sequence. Nothing….
  4. The only lights that come on are the following:
a. Pots & pan & headed dry
b. Normal & headed dry
c. Light & headed dry
The headed dry light automatically comes on when you push one of the three wash types above.
  1. I replaced the electrical control board and same symptoms.
Any feedback or recommendations are appreciated.
Thank you!
