frig keeps running wont shut down…I think it may be the run capacitor because it controls on and off…
Hi.
How do you know the fridge is running non stop?
Does the temperature in the fresh food compartment normal?
Do you see any frost build up at the rear panel in the freezer?
Thank you. Post the results.
Simon.
there is frost in freezer now…frig has been running about 5-6 days without shutting down…temp has come down to 35 degrees in the frig…I have unplugged it and when plugged back in,it stays running again…in live chat,they suggested it was the defrost cntroller
Hi.
Check the door gaskets for air leak. If that seams to be OK,
replace the cold control 2325700
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5510163
Simon.
