Whirlpool Washer Beeps
Whirlpool Front Load Washer Duet TumbleFresh 4.0 Cu. Ft. Beeps and then
stops.
Take off the top by taking out the screws in the back and you should find some tech notes that will tell you how to put it into diagnostic mode and generate error codes.
The notes will then tell you how to interpret the codes and how to test the components.
This sounds like a door lock assembly problem, so start there.
I replaced the door lock assembly, but it still beeps. The washer will wash and drain. It will not go into the spin cycle. I have the tech sheet, but can not figure out the code. This machine does not have a digital display. After the wash cycle, the machine will beep once, pause and then 6 beeps. I am thinking of changing the electronic control. Part # W10525361
Thank you
Thank you
Thank you
Okay, on units without a display the flashing LED are giving you the error code.
If you go through the tech sheet you will see how to put it into diagnostic mode and generate the error codes, if there are any.
If you are really stuck you could replace the MCU and/or the CCU on spec, and if you order from this site you can return the parts if they are not needed.
