Whirlpool washer, no drain or spin
My Whirlpool washer will not drain or spin in any cycle. It did go thru the wash cycle, but when pause/spin cycle hits, the machine just sits there fat, dumb & happy. :cool:
I removed the drain pump and it appears OK. Nothink stuck in the drain line. My guess is the timer since the the same thing happens in all cycles. Possibly a shory in the pause/spin control?? :confused:
Any feedback would be greatly appreciated. :wink:
Check the lid switch, the chances are much greater that is the problem than the timer.
Thanks very much for the info. I checked it last night and sure enough it was split open in two. New part is on order.
Great, glad you found it and can make the repair. And thanks for updating us.
