Whirlpool Washer Not Spinning
Washer Not Spinning. All other cycles work fine and the timer advances through each cycle to completion. Coupling is fine and the clutch is very tight. In high spin, it does the two short rinses and does drain but no spin. In low spin, it does the two short rinses but does not drain or spin. Mostly just the timer "ticking" and no other sound. In neither spin cycle does it sound like anything is dropping to engage. Again, motor is activated to drain on high spin but no activity on low spin other than some water and the timer noise. Have not removed cabinet to visually inspect lid switch but unhooked and ran temporary white/grey jumper. It allows me to view agitate fine for example.
Thanks much!!!
