Whirlpool Washer relay problem
In any cycle the washer reaches a point where it should drain and spin, drains but does not spin to complete draining process.
Activating the interlock switch a couple of times manually kicks it into spin mode and draining is completed.
Steps ok to the next cycle but again without the manual intervention it does not activate the spin mode.
Have you checked the lid switch (#11 on the [B]diagram[/B])?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=257402
Ice maker ejection system cycles when toggle switch is pressed continuosly but seems to stop when the switch is released. Water is not filling the tray but is available for the water dispenser. The switch does not appear to remain in the | position but goes back to neutral. I have also seen a spark in the toggle area.
Is it the switch? What parts should I replace? How do you remove the icemaker unit to from the freezer? Do I need any special tools?
