Whirlpool washer with flaky control knob
This washer works only when you pull and hold the main control knob. What part needs to be replaced?
TIA,
nfarlow
— Begin quote from nfarlow;300073
TIA,
nfarlow
If you are talking about pulling on the timer knob, then you need a new timer. One or more of the contacts inside are probably almost burnt away.
Part number AP3018613
— Begin quote from ThatGuy;300084
Thank you for your quick reply.
Will this timer work?
http://www.**************************.com/ShowProduct.aspx?ID=20135
Sorry, I didn’t know this site blocked URLs. The part number is Washing Machine Timer - 3946448
— Begin quote from nfarlow;300100
It should, it crosses back to the other timer number.
