My 7 year old Whirlpool washer won’t spin when clothes are in it. Or I can get a very slow spin out of it if the clothes aren’t heavy. At first I thought it was the lid switch–now I wonder if it is something else. Everything else on it works fine.
We did follow the videos and took it apart but can’t figure anything. Did find a fine oil spray on the inside of the cabinet, about 6 inches up from the bottom, arching to about 4 inches above the bottom, back to front. There used to be a small oil leak noticed when I pulled it once a year to clean under/behind it, but that wasn’t there this year.
Putting it back together, we found one of the screws holding the control panel stripped/broke the plastic holder. The machine still works fine, except it won’t spin with wet towels (my latest load).
Thank you for any help, ideas, suggestions, parts to buy.
