I’ve been reading what I can, but I don’t think my issue is quite the same as the others so I’m asking for a diagnosis.
Here’s what I can tell you:
[LIST]
*]The washer will not spin.
*]It will agitate.
*]It will fill & drain.
*]The pump is clean and clear as are the hoses to the pump and exiting the pump.
*]The motor will drive the gearcase and the top spindle of the gearcase will turn.
*]Last but not least, I caused the issue. (I washed a down pillow that exploded in the washer) Some feathers are still showing up but it’s very minor so I don’t believe them to be causing an ongoing issue.[/LIST]This all said, does anyone know what the issue might be? I can’t really afford a repairman right now so I’m looking to do it myself. Any information is greatly appreciated. Thanks in advance.
