No hot water will enter the washer. It will fill with "cold" water on the cold and warm settings. As soon as you select "hot" the water shuts off. I checked the inlet screen on the hose and it is clean. Do I need to replace the inlet water valve? thank you
I would agree with changing the water valve.
Nat
