Whirlpool washer
The washer in question spins unevenly although there are no clothes in the tub. Any ideas? Machine is level and runs fine other than the spin cycle is uneven and noisy.
Hi,
I would check the suspension springs, suspension pads, and skate plate.
— Begin quote from ApplianceJunk;615603
Hi,
Thank you for the help
Your welcome,
Did you get it repaired?
Ordered springs for it hope that does it. All else looked good.
Let me know if the does the trick or if you need any more help.
Thanks again. Are those springs hard to replace??
I have no idea how handy you are. I find them easy to replace.
Here is the service manual for your washer, maybe you will find it helpful.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=30
