whirlpool washer
all systems are a go, but start button flashes when you push it, no code come on and neither does the washer :confused:
— Begin quote from bibbs1;759200
all systems are a go, but start button flashes when you push it, no code come on and neither does the washer.
Run the diagnostic test as described in the attached tech sheet and post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5141487
