Whirlpool Washing Machine (replacing coupling)
[SIZE=5]I have to replace the coupling. Is there a step by step procedure to do this?
Bernie
[/SIZE]
Remove the pump and motor and replace the coupler. Turn the tranny coupler clockwise till the spin basket starts to turn. If hard to turn with thumb and forefinger, you have bad brake shoes. Post results.
Whirlpool (also Kenmore, Kitchen Aid, Roper, Estate, and Kirkland washers) direct drive washer coupling AP3963893
[SIZE="5"]Here is how to replace the Whirlpool washer coupler, step by step - http://www.repairave.com/washerrepair_wpl_motorcoupling.asp[/SIZE]
We have been running our washer for a while without a clothes guard and it is now starting to run out of balance and spill water out the top with large loads. Will I need to replace the snubber pad or any thing else if I replace the clothes guard?
