Hi All,
Last night went to check washer and selector dial knob was pointed to Rinse but nothing was happening other than a humming noise. I manually advanced knob to spin and that worked fine. It then occurred to me that the clothes probably had had not rinsed and and thought I’d better try a full wash cycle again. It’s doing nothing but spin and only when I turn the dial manually to that position. This is true for all the wash modes around the dial - only spin will work.
I know it filled and ran thru the cycle that initial time until it got stuck at rinse and I noticed.
I removed the supply hoses and made sure the input screens were clean and I had good water pressure.
Anything I can check first to diagnose before I start throwing money at parts? I have a voltmeter and tools and I’m pretty handy if I know what to look for.
Thanks for the help in advance!
