whirlpool WDF760SADM2 leaking from under door
Hello,
My 4 year old Whirlpool washer started leaking from under the door on the left side. The front part of the under pan gets filled to the very top. Should the water get that high in this area??? the leak started after i replaced the sump as the grommet there was leaking. I have no idea if its related or not. I already invested 100$ into sump. If i need another part i cant afford to make a mistake. Please help! Thanks
