Whirlpool wont fill
My washer won’t fill …checked water hoses no leaks…electric is fine…it will agitate just wont fill with water any ideas?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WTW5505SQ1
See he attachment for the tech sheet.
Sounds like the unit thinks that it is already full.
Could be a bad fill switch (Item 12 in Section 4)
Unplug the unit and the V wire at the fill switch, set the timer to off.
Then measure it with a meter.
V to P should be 0 ohms.
V to T should be infinite ohms.
