I have a whirlpool duet washer (model wfw8740dw). The machine will do a load of wash until it starts the high speed spin. It will start for a few seconds and stop. Then the machine will sit and time out. I have checked the drain pump. Everything is clear, no obstructions. I have proper voltage and continuity to the pump. I did change the pressure switch. I had +.5 oms. the door lock/switch has been replaced as well as the four shocks. The ccu has a solid green light and proper voltage to the ccu. I can do a diagnostic test with no codes, but times I cannot do a diagnostic test. I am thinking of checking wiring harness for continuity and then possibly replace ccu. Any input would be greatly appreciated. Thank you for your time.
Related topics
Whirlpool Duet Sport won't spin at high speeds... wet clothes | 4 | 14430 | June 15, 2012 | |
Whirlpool Duet Sport | 3 | 2177 | May 15, 2012 | |
My Whirlpool duet won't spin, No error codes | 1 | 4185 | August 30, 2010 | |
Whirpool Duet Sport doesn't go into high spin | 11 | 10684 | December 2, 2009 | |
No Spin | 3 | 1378 | April 8, 2010 |
