Whirpool Quiet Partner III stops randomly
Hello!
I have a Whirpoll Quiet Partner III that is about 5 years old. Recently I have noticed that if I start a load, at some point it stops, as I’ll come by and notice it not running, and notice the LED display shows "–" blinking as it would if you opened the door partway through the cycle. If I press up against the door I hear a small ‘click’ and away it goes, back to normal. So I think there is something wrong with the latch or switch(es) or a sensor in that general area. Not a dishwasher expert, but I am handy. I’ve got the front door pulled apart and am looking at the handle/latch area. I see two switches, everything seems OK. Is maybe something getting worn down somewhere in this area? Any ideas? Thanks! The problem is getting progressively worse. Yesterday I was not able to get it to continue washing simply by pushing on the door. I had to open it, fiddle with the metal thing that sticks out of the washer (and goes into the door when you close it), and then i was able to get it to ‘click’ and start back up again.
Thanks in advance!
Edit: The little thing that i fiddle with is apparently called the ‘strike’ and I’m starting to wonder - could the be wearing out? Maybe not ‘springy’ enough to hold the switch down anymore? The switches and latch appear to be fine…
