i CHANGE THE LID SWITCH OF MY WASHER AND NOW AFTER I HOOK UP THE MACHINE I CAN’T FILL OUT WITH WATER(COLD OR HOT).
THE ONLY THING THE WASHER DO, RIGHT NOW, IS SPINNING.CAN YOU HELP ME???
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=266281
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203954565.pdf
Why did you change the lid switch in the first place?
Could be you knocked a wire off in the control panel at the timer or the fill switch.
