my dryer won’t start when i press and hold the start button. the interior light also stays on, the timer light flashes and it gives 3 rapid beeps. could this be a bad door switch? it’s an older model but hasn’t seen alot of use.
— Begin quote from wilcollc;271941
Wilcoll,
Yes it could be a bad door switch, or a loose wire connection.
It could also be a bad main control board, but let’s hope not.
What about the door, does it activate the switch when you close it ?
The easy test is at the main control board on connector P1.
Pin2 (white) and pin 3 (blue).
On the wires in the connector,when you remove the connector from the board, with the door closed your meter should read a closed circuit, open circuit with the door open.
Anything other than that would indicate a bad switch or broken wire.
If you have the proper readings then you’ve got a bad main control board.
[part]AP3135340[/part]
[part]AP3179731[/part]
[part]AP3775548[/part]
Good Luck,
