Hi, My MayTag washer will not get out of the rinse cycle. This still stay in the cycle forever. I have manually stop it and move it to the next spin cycle. Any help on this problem? thanks for your support.
It sounds like a bad timer motor. Only problem is you can’t buy the motor separately from the timer. Check out this link to the timer. Hope this helps.
http://www.appliancepartspros.com/part_details.aspx?part_id=3967873
Thanks for replaying on my thread. Do you have any insturctions to replace the timer? Will order the timer on Monday.
