Will not circulate water /impellor free
I have Bosch dishwasher , will not circulate the water. Checked and replaced watershutoff valve, also checked the impellor to verify it is free.
Does it fill up with water?
Remove the kick plate and check if the circulation pump motor works while the control calls for wash. Post the results.
The model number you posted does not come up. Verify and repost it please.
circulation pump works if I apply 110v to it its self, Also cleaned and che
cked what looked like a float switch, checked same switch in on and off position,checked ok.
Yes it does fill up with water.
Did you check the circulation pump when it should be powered up by the dishwasher control?
Gene,
Thanks for the help, I believe I have it figured out. I opened it all up, and hooked up again found out very thing would run and cycle. So I ordered the Circulation pump rebuild kit? Hope this works?
Definitely it will if the motor itself is still good. Keep us posted.
Gene,
Thanks for all the help. Works like a champ!!
You are welcome. I’m glad it’s up and running.
