Will not complete drain and spin until cool down
My washer runs ok until it reaches the drain and spin point then it stops. If you turn the timer off and wait 15 min, it starts and completes the wash. Can you help with this issue?
Leave the timer turned on and see if it starts up automatically after 15 minutes, if so that confirms a bad motor. Also, your timer may have burnt contacts causing the motor to overheat. Just pull cover and check.
I left the timer in the on postion and the machine made a soft humming noise after 15 mins, still did not drain. I out the timer in the off position and waited 15 mins, this time the it hummed and pump started. Motor or timer issue?
