My washer fills up with water but then does not agitate, spin and does not drain. You can see it try to spin and then it stops. Since it does not cycle it will not drain either. Please give advice, will try anything…
I would look for a sock stuck in the water pump.
Go to %url% for info on this direct drive washer.
