Will not fill during rinse cycle
Sometimes during rinse cycle the water will drain out as it is filling. This is an intermittent problem.
You may have a siphon problem, so check the discharge hose and make sure it high enough. The pump on this is electric, so if it is coming on the timer may be the problem.
