Will Not Spin - Need Ideas
GE Washer Model WJRE5550K2WW will not spin. Pump works and drains just fine. Lid switch works, the water level switch checks out, there are no codes coming up on the motor LED, belt is in good shape, inner tub can be easily turned by hand in either direction. I tried a reset and it made no difference. The timer is a computerized model and I do not know how to check it but I have done everything else that I can think of to find the problem. Any ideas? Washer is 7 years old
