will not spin
Hi,
Wsahing machine will come on, water comes out…but no spin.
Take off the front panel and look at the belt/motor area and see if you can determine if the problem is a broken belt, loose belt, motor not turning etc.
Thanks, and post your results if you are unable to diagnose the problem.
