Wind noise in freezer
Side by side unit is 2.5 years old. Noise heard from outside when door closed but louder when door is open. The wind/sound of rushing air surges from time to time and comes from inside the top rear of the freezer. Temp in frig and freezer ok and no other problems noted except the noise. Is this a noisy evap fan? If so, how do you get to it? By removing the ice maker? I can fix about anything with a repair manual but cannot locate one. Thank you.
I have the GSH25JSRF SS model (ignore what I wrote in the subject line. it’s the wrong model number). I experience the same thing. Would replacing the motherboard fix mine too? Where can I find a new motherboard if it’s not under warranty and if there’s no recourse via class action?
Thanks everyone!
wll the mother board fix the problem with the ice maker not turning ice out the door water works fine and makes lots of ice but won’t come out the front door why is that ??? anyone know :confused:
Yes, the motherboard contains the auger motor driver. Replacing the board should fix this problem.
thank you for info is there a part# that you could tell to use model # i have is GSH25JSRFSS THANKS AGAIN
Same # that Gene gave, AP4297272
washer leaking from underneath, can see water dripping when i tilt it back. help please
— Begin quote from not a clue;214089
sorry, I think that model may be 3954259
I have a Kitchen aid Refrigerator and it appears that the filter housing is leaking. Is this possible. I have it apart and can not see anything wrong with it but it is dripping water out of it. I hate to spend 50.00 bucks on itif this is not the problem. Thanks.
