Wiring for heating coil Amana Dryer
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=629898&pkw_=basket&model_id=19445&NewWindow=1
Above is the diagram for the Heating coil. The two leads going to the heating coil are orange and black. I have placed two thermastast on the board. The orange terminal goes direct to the terminal on the heating coil… My question is the black lead is on a piggy back connection ( where two black leads go on to one terminal) this doesn’t seem right to me. I have not added this piggy back connection but I may have inadvertantly attached the main lead to it. I believe the main lead should be attached to the #6 thermostat which then leads to # 8 which then is connecet to the heating coil terminal…Help my wife is going to kill me LOL
This should help
http://www.servicematters.com/maytag_library/docs/RS3200005R2.pdf
Am not 100% sure on your question and do not want to be responsible for an arc & spark so am not going the answer it directly but the above service manual should help you figure it out. See pages 11-25 1nd 11-26
