I have a whirlpool washer less than 10 years old. MY problem, the washer will fill to desired level, quits filling. Then nothing. No humming from the timer or the drive motor. Timer will not advance it just sits there. I checked all connections for tightness and corrosion. No leaks found. All appears to be good. Suggestions would be very much appreciated.
Probably a bad [this video](http://www.appliancepartspros.com/whirlpool-lid-switch-assembly-3949247-ap3100003.html"water level pressure switch]lid switch[/URL]. Advance the timer to see if it will drain or spin. If nothing, it’s most likely the lid switch. If it does drain/spin, the lid switch is ok and it’s most likely the . If it’s the lid switch, you can bypass it temporarily til you get a new one. See [URL="http://www.youtube.com/watch?v=XAnQ6Ovvnuc), your switch type is the second one in the video.
Eric
Thanks for the additional input, I forgot to mention that advancing the timer does nothing. when I advance the timer the only activity I get is when I hit the points in the cycle that require water.( rinse cycles ).It will fill but wont drain. No aggitation, No spin, no humming, no nothing.
Thanks For your help.
