i cant even figure how to look for the belt but my machine wont agitate or spin it fills with water and drains the water but thats it
Does the motor run on spin and/or agitation?
In order to access the belt and other parts inside you have to remove the front panel.
Here are the break down diagrams fro the GE washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=530892&&model_id=231098
the motor works the belt looks good and looks like everything is turning but the belt
