Won't drain or spin
This washer will not drain or spin in most cycles. It agitates well, but when the drain or spin portion of the cycle comes around, nothing happens. There is no sound from the washer except the ticking of the timer. It is possible to move the timer to to the drain and spin sections of the "delicate" cycle and then it will drain and spin normally.
This sounds like the timer to me, but I wondered if there are any other opinions,
Thank you.
