Won't dry properly
My whirlpool dryer will go through it’s drying cycle but the timer always reverts to 51 minutes and even after it has "completed" it’s cycle it will automatically revert to 51 minutes. I’ve even unplugged to erase the system and when I plug it in, it automatically goes to 51 minutes. Any ideas about why?
A Model Number may help others help you.
There are Duets and Duet Sport models.
Note if you are from Saskatoon let us know which it is along with the Model Number as Canadian Model Numbers sometimes are not the same as US numbers.
The ice/water dispenser stopped working though it still makes ice. I’ve removed the front control panel and the switches are making good contact with the paddles. The ice chute door opens properly. What is my next step?
Thanks.
