My microwave oven quit working. the humidity sensor shows it is open so I jumped out the sensor and everything works ok except that it will not heat. I put a neon bulb and a cup of water in the oven but the bulb will not stay on very long and the water temp. will only rise very little. The HV capacitor checks ok with a capacity checker (1.1 uf ) and the diode shows resistance in one direction. The Hv transformer has 120 volts ac when I push the start button. I don’t know what the resistance reading should be for the transformer primary or secondary. The magnetron between f and Fa is not open nor is it shorted to ground. Could it be possible for the capacitor to be breaking down after the power is on for a short time even though is checks ok with a meter? Anyone have any sugestions?
Related topics
Oven not heating | 7 | 6464 | April 30, 2009 | |
Microwave help PLEASE!!! | 4 | 1618 | October 19, 2010 | |
ge microwave does not heat, everything else works | 1 | 2992 | April 8, 2010 | |
GE Microwave not heating | 5 | 5383 | August 31, 2012 | |
Microwave won't heat | 13 | 5941 | January 7, 2013 |
