won't run
Any help would be appreciated. I replaced the timer on my Maytag LAT9804AAE a little over 1 year ago because it would spin but not agitate. It has worked well until this morning when the power and spin lights both lit up but the machine would not fill. I have checked both lid switches and am getting power through both. I am not getting anything to the temp switch. I suspect the timer assembly again but would like confirmation. I don’t want to replace it unless I have to.
I suspect the timer also, but I think it would be unusual for it to fail again.
Here is a service manual with a wiring diagram for your machine (page 5-3). Check the water level switch, the temp selection switch and also see if you can find the fuse that is in-line to the water level switch and test it.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
Great, glad you got it working at no cost, and thanks for the update.
