Help, keep getting ul code during spin cycle, already have taken apart and clean up any corrosion that may have built up, there was hardly any, step two, removed and replaced suspension spring kit, worked for three days now it right back to the ul code, what is next, bearing? does make some grinding noise when inner tub is moving or faulty sensor, does it with or woth out clothes
Related topics
ul code after we changed the spring kit | 1 | 548 | January 14, 2015 | |
Spin Cycle Continues Togive Ul Code | 3 | 1051 | July 27, 2013 | |
UL issues after replacing drive shaft | 2 | 620 | January 15, 2015 | |
Still getting UL code | 1 | 524 | August 26, 2015 | |
Maytag bravos washer | 1 | 971 | September 8, 2013 |
